Ferdinando Criscuolo
Eclipse Indigo: Problem compiling
Discussion created by Ferdinando Criscuolo on Dec 28, 2011
I tried to compile a simple project with Eclipse that includes the header files (are the header files used for the management of the accelerometer on the i.mx53 qsb)
#include <linux/module.h>
int main(int argc, char **argv)
    return 1;
the compiler does not find such header file. For example asm/processor.h. Looking this file is in another folder. What's wrong?
I do not think is a configuration problem of eclipse because i can compile other projects.
thanks
