/*** ATDCTL01 - ATD Control Register 01; 0x00000080 ***/typedef union { word Word; /* Overlapped registers: */ struct { /*** ATDCTL0 - ATD Control Register 0; 0x00000080 ***/ union { byte Byte; struct { byte WRAP0 :1; byte WRAP1 :1; byte WRAP2 :1; byte :1; byte :1; byte :1; byte :1; byte :1; } Bits; } ATDCTL0STR; #define ATDCTL0 _ATDCTL01.Overlap_STR.ATDCTL0STR.Byte #define ATDCTL0_WRAP0 _ATDCTL01.Overlap_STR.ATDCTL0STR.Bits.WRAP0 #define ATDCTL0_WRAP1 _ATDCTL01.Overlap_STR.ATDCTL0STR.Bits.WRAP1 #define ATDCTL0_WRAP2 _ATDCTL01.Overlap_STR.ATDCTL0STR.Bits.WRAP2 #define ATDCTL0_WRAP0_MASK 1 #define ATDCTL0_WRAP1_MASK 2 #define ATDCTL0_WRAP2_MASK 4 /*** ATDCTL1 - ATD Control Register 1; 0x00000081 ***/ union { byte Byte; struct { byte ETRIGCH0 :1; byte ETRIGCH1 :1; byte ETRIGCH2 :1; byte :1; byte :1; byte :1; byte :1; byte :1; } Bits; } ATDCTL1STR; #define ATDCTL1 _ATDCTL01.Overlap_STR.ATDCTL1STR.Byte #define ATDCTL1_ETRIGCH0 _ATDCTL01.Overlap_STR.ATDCTL1STR.Bits.ETRIGCH0 #define ATDCTL1_ETRIGCH1 _ATDCTL01.Overlap_STR.ATDCTL1STR.Bits.ETRIGCH1 #define ATDCTL1_ETRIGCH2 _ATDCTL01.Overlap_STR.ATDCTL1STR.Bits.ETRIGCH2 #define ATDCTL1_ETRIGCH0_MASK 1 #define ATDCTL1_ETRIGCH1_MASK 2 #define ATDCTL1_ETRIGCH2_MASK 4 } Overlap_STR; struct { word ETRIGCH0 :1; word ETRIGCH1 :1; word ETRIGCH2 :1; word :1; word :1; word :1; word :1; word :1; word WRAP0 :1; word WRAP1 :1; word WRAP2 :1; word :1; word :1; word :1; word :1; word :1; } Bits; } ATDCTL01STR;extern volatile ATDCTL01STR _ATDCTL01 @(REG_BASE + 0x00000080);#define ATDCTL01 _ATDCTL01.Word#define ATDCTL01_ETRIGCH0 _ATDCTL01.Bits.ETRIGCH0#define ATDCTL01_ETRIGCH0 _ATDCTL01.Bits.ETRIGCH0#define ATDCTL01_ETRIGCH0 _ATDCTL01.Bits.ETRIGCH0#define ATDCTL01_WRAP0 _ATDCTL01.Bits.WRAP0#define ATDCTL01_WRAP1 _ATDCTL01.Bits.WRAP1#define ATDCTL01_WRAP2 _ATDCTL01.Bits.WRAP2#define ATDCTL01_ETRIGCH0_MASK 1#define ATDCTL01_ETRIGCH1_MASK 2#define ATDCTL01_ETRIGCH2_MASK 4#define ATDCTL01_WRAP0_MASK 1024#define ATDCTL01_WRAP1_MASK 2048#define ATDCTL01_WRAP2_MASK 4096
Message Edited by PsychoDebugger on 2007-04-1710:08 AM
Euh, checking is a bit fastidious.
I enclosed the definition from CodeWarrior so you can copy/paste.
Cheers,
Alban.
