Hello
Thank your for your wonderful reply.
The following is configured for reception:
i have configured 6 Acceptance filters for receiving six messages and a single filter for receving messages with the ID for 0x480 ----0x48F .( i am supposed to receive 4 messages within these id's) hence i have alloted a common filter.
in the RX interrupt routine i am doing the following;
1. disable the RX interrupt.
2. Find the filter that is hit
3. Copy the data
4. clear the RXF flag which caused the ISR.
Even after making these changes i could see the error frames.( This i did after you mentioned earlier that the RX-ISR routine may be large enough to miss any incoming interuupts).
i have not implemented the error interrupt routine in the code. Can you please tell me the error frames may be due to not implementing the Error-ISR??
Thank a Lot
Jlraj
