Xiao Sheng Lin
HC08QC8 programming issue with P&E Multilink
Discussion created by Xiao Sheng Lin on Apr 4, 2007
Latest reply on Apr 4, 2007 by Alban Rampon
Hi, I am using a P&E Multilink to program code into QC8 chip. However, I always encounter this problem during flashing procedure.
"Trying Security $FFFFFFFFFFFFFFFF Access Denied.
   (68HC08 Device responded properly, but ROM is secure.)
ERROR 48 during script!"
It is not caused by my program, because I use CodeWarrior to generate a fresh new QC8 code to try.
But if I only change the device setting to QC4 or QY4, the flashing works.
Is there any compatibity issue between Multilink and QC8? Thanks!
