8-bit MCU Downloads... can't see anything there?
PHa
I'm looking for info about OSBDM08 Hardware/software, but I can't see any downloadable files etc. when browsing to 8-bit MCU Download page(first message at OSBDM board claims that OSBDM Hardware info can be found at 8-bit MCU Download page).
Why can't I see dowloadable files. Also when I tried to search e.g. with keyword I get info that claims that searched subject doesn't exist.
What's wrong, hah?
PHa
Tags (2)
Alban
Senior Contributor II
Hello Pha,
I am changing the page in question.
The OSBDM08 board is new. OSBDM08 posts were previously part of the 8-bit MCU board.
When I separated the boards, I moved the posts but not edit to reflect the new post locations.
There are several OSBDM08 versions, I advise you to read
in order to chose which version matches your needs.
Alban.
peg
Senior Contributor IV
Hi PHa,
As this uses the search facility I believe the problem may be the same as in this thread.
I don't know a way around it though, its been a long time since I looked in there.
joerg
Hi PHa
The Firmware can be found:
http://forums.freescale.com/freescale/board/message?board.id=OSBDM08&message.id=2&view=by_date_desce...
Information about Hardware:
www.systech-gmbh.ch -HC(S)08-System -programmer
Saluti Joerg
PHa
Hi Joerg,
And Thanks for guiding me to a right direction,
just the material what I was looking for !
PHa
