configure I/O
configure I/O
dspfusm
HI!!!!
I need to konw how i configure a pin to GPIO to  in or out.
thanks
Message Edited by Alban on 2007-03-30 12:36 PM
Alban
Senior Contributor II
Your subject does not match requirements and you don't give any details.
This is not possible to help you when you give nothing.
Please read the rules if you don't want your messages to be deleted.
Alban.
peg
Senior Contributor IV
Seeing how we are talking about the general case here, the answer is:
By setting or clearing the appropriate bit in the appropriate direction control register.
Alban
Hi David,
If you had not answer this post, I would have deleted it.
Alban.
peg
It was only meant as a satirically useless answer to point out the useless nature of the question.
