WinCE 600 Dual Display set DI0 as main display, DI1 as secondary display.
Freescale semiconductor
Version: 1.0
Author: Justin Jiang
Date: Fri 11/25/2011
1. Description
- This is Dual display for Freescale MX51 release(WinCE 6.0).
2. File List
- Patch: code base on WINCE600_MX51_ER_1104.
3. Requirement
- i.MX51 BBG. DI0 connected to a DVI dispaly with 1024*768 resolution.
DI1 connected to a WVGA display with 800*480 resolution.
4. How to use the patch
- Please merge the patch files to your installed bsp code. You can remove the debug message code by yourself.
- After boot up, please run the DisplaySet.exe.
Click the Apply button it will enable the secondary dispaly on DI1.
- Then you can run mosquito_dual.exe, it will show on secondary display.
5. History
- N/A
6. Known Issues
- Need customer change the mapping file with their panels.
- Secondary display size may need reset in the code.
7. Additional Resource
- N/A
Original Attachment has been moved to: 500-WINCE600_DualDisplay_DI0Main.zip
