LIN tesing on DEMO9S12XDT512
tranvkhoa
Hello everybody
I have bought DEMO9S12XDT512 from Freescale, now I want to test LIN
communication between these boards but I cannnot find LIN driver for
this kind of MCU. Could you please help?
Khoa
Alban
Senior Contributor II
You should start by searching in the product page.
It gives pertinent entries like:
AN2732
Using XGATE to Implement LIN Communication on HCS12X
Others are also available there.
Alban.
tranvkhoa
Dear Alban
Thanks for your reply. Is there any software for AN2732? I cannot find one.
Khoa
J2MEJediMaster
Specialist I
The listing for the driver is within the file. I have searched and don't see a separate file that contains the software.
---Tom
BuiHieu
Dear Mr.Alban,
       I have read AN2732 carefully, but I can't know how to use those codes inside. Could you please explain to me more detail? Please sent to me an example code if you have.
      Thanks you alot!
Ngoc Hieu
Alban
Information on how to use the XGATE library is located in the following document:
AN3145
XGATE Library: Using the Freescale XGATE Software Library
Alban.
