ltib for imx51 board - ltib error
computer996633
fsl_shw_rand.c:46:24: error: shw_driver.h: No such file or directory
fsl_shw_rand.c:49: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'validate_uco'
fsl_shw_rand.c:56: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fsl_shw_get_random'
fsl_shw_rand.c:84: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fsl_shw_add_entropy'
make[1]: *** [fsl_shw_rand.o] Error 1
make[1]: Leaving directory `/home/auto/Varadharajan/YBV/L2.6.31_09.12.00_SDK_source/Nov16/ltib/rpm/BUILD/imx-lib-09.12.00/rng'
make: *** [rng] Error 2
error: Bad exit status from /home/auto/Varadharajan/YBV/L2.6.31_09.12.00_SDK_source/Nov16/ltib/tmp/rpm-tmp.84200 (%build)
RPM build errors:
Build time for imx-lib: 0 seconds
Failed building imx-lib
f_buildrpms() returned an error, exiting
traceback:
 main:560
Started: Thu Nov 17 12:36:37 2011
Ended:   Thu Nov 17 12:37:28 2011
Elapsed: 51 seconds
These packages failed to build:
imx-lib
Build Failed
KrishnaPavan
Hi, Varadharajan,
Were you able to resolve the error with the build, by now?
If not then,
Did you configure your ltib properly?
From your log it seems there is some problem with the configuration itself.
Regards Krishna Pavan
