David Fitzgerald
Building Qt for i.Mx233
Discussion created by David Fitzgerald on Nov 16, 2011
Latest reply on Nov 24, 2011 by David Fitzgerald
Hello
I have a new Ubuntu 10.04 host and have been trying to build qt4.7.3 for embedded linux following this guide - http://www.imxdev.org/wiki/index.php?title=All_Boards_Qt
I can get up to the section of building Qt/Target but fail with this error:
engineering@engineering-desktop:~/qt-everywhere-opensource-src-4.7.3$ export PATH=$PATH:/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin
engineering@engineering-desktop:~/qt-everywhere-opensource-src-4.7.3$ ./configure -v -embedded arm -xplatform qws/linux-arm-imx -phonon
Which edition of Qt do you want to use ?
Type 'c' if you want to use the Commercial Edition.
Type 'o' if you want to use the Open Source Edition.
o
Determining system architecture... (Linux:2.6.32-35-generic:i686)
    32-bit Intel 80x86 (i386)
    'arm' is supported
    'i386' is supported
System architecture: 'arm'
Host architecture: 'i386'
You have not explicitly asked to use pkg-config and are cross-compiling.
pkg-config will not be used to automatically query cflag/lib parameters for
dependencies
Precompiled-headers support enabled.
Symbol visibility control enabled.
This is the Qt for Embedded Linux Open Source Edition.
You are licensed to use this software under the terms of
the Lesser GNU General Public License (LGPL) versions 2.1.
You are also licensed to use this software under the terms of
the GNU General Public License (GPL) versions 3.
Type '3' to view the GNU General Public License version 3.
Type 'L' to view the Lesser GNU General Public License version 2.1.
Type 'yes' to accept this license offer.
Type 'no' to decline this license offer.
Do you accept the terms of either license? yes
Creating qmake. Please wait...
g++ -c -o option.o -pipe -DQMAKE_OPENSOURCE_EDITION -I. -Igenerators -Igenerators/unix -Igenerators/win32 -Igenerators/mac -Igenerators/symbian -I/home/engineering/qt-everywhere-opensource-src-4.7.3/include -I/home/engineering/qt-everywhere-opensource-src-4.7.3/include/QtCore -I/home/engineering/qt-everywhere-opensource-src-4.7.3/src/corelib/global -I/home/engineering/qt-everywhere-opensource-src-4.7.3/src/corelib/xml -I/home/engineering/qt-everywhere-opensource-src-4.7.3/tools/shared -DQT_NO_PCRE -DQT_BUILD_QMAKE -DQT_BOOTSTRAPPED -DQLIBRARYINFO_EPOCROOT -DQT_NO_TEXTCODEC -DQT_NO_UNICODETABLES -DQT_NO_COMPONENT -DQT_NO_STL -DQT_NO_COMPRESS -I/home/engineering/qt-everywhere-opensource-src-4.7.3/mkspecs/qws/linux-x86-g++ -DHAVE_QCONFIG_CPP -DQT_NO_THREAD -DQT_NO_QOBJECT -DQT_NO_GEOM_VARIANT  option.cpp
g++ -o "/home/engineering/qt-everywhere-opensource-src-4.7.3/bin/qmake" project.o property.o main.o makefile.o unixmake2.o unixmake.o mingw_make.o option.o winmakefile.o projectgenerator.o meta.o makefiledeps.o metamakefile.o xmloutput.o pbuilder_pbx.o borland_bmake.o msvc_vcproj.o msvc_vcxproj.o msvc_nmake.o msvc_objectmodel.o msbuild_objectmodel.o symmake.o initprojectdeploy_symbian.o symmake_abld.o symmake_sbsv2.o symbiancommon.o registry.o epocroot.o qtextcodec.o qutfcodec.o qstring.o qtextstream.o qiodevice.o qmalloc.o qglobal.o qbytearray.o qbytearraymatcher.o qdatastream.o qbuffer.o qlist.o qfile.o qfsfileengine_unix.o qfsfileengine_iterator_unix.o qfsfileengine.o qfsfileengine_iterator.o qregexp.o qvector.o qbitarray.o qdir.o qdiriterator.o quuid.o qhash.o qfileinfo.o qdatetime.o qstringlist.o qabstractfileengine.o qtemporaryfile.o qmap.o qmetatype.o qsettings.o qlibraryinfo.o qvariant.o qvsnprintf.o qlocale.o qlinkedlist.o qurl.o qnumeric.o qcryptographichash.o qxmlstream.o qxmlutils.o
floatmath auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o floatmath.o floatmath.cpp
floatmath.cpp:44: warning: unused parameter 'argc'
floatmath.cpp:44: warning: unused parameter 'argv'
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -Wl,-O1 -Wl,-rpath,/usr/local/Trolltech/Qt-4.7.3/lib -o floatmath floatmath.o
floatmath enabled.
mmx auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -mmmx -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o mmx.o mmx.cpp
cc1plus: error: unrecognized command line option "-mmmx"
make: *** [mmx.o] Error 1
mmx disabled.
3dnow auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -m3dnow -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o 3dnow.o 3dnow.cpp
cc1plus: error: unrecognized command line option "-m3dnow"
make: *** [3dnow.o] Error 1
3dnow disabled.
sse auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -msse -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o sse.o sse.cpp
cc1plus: error: unrecognized command line option "-msse"
make: *** [sse.o] Error 1
sse disabled.
sse2 auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -msse2 -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o sse2.o sse2.cpp
cc1plus: error: unrecognized command line option "-msse2"
make: *** [sse2.o] Error 1
sse2 disabled.
sse3 auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -msse3 -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o sse3.o sse3.cpp
cc1plus: error: unrecognized command line option "-msse3"
make: *** [sse3.o] Error 1
sse3 disabled.
ssse3 auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -mssse3 -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o ssse3.o ssse3.cpp
cc1plus: error: unrecognized command line option "-mssse3"
make: *** [ssse3.o] Error 1
ssse3 disabled.
sse4_1 auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -msse4.1 -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o sse4_1.o sse4_1.cpp
cc1plus: error: unrecognized command line option "-msse4.1"
make: *** [sse4_1.o] Error 1
sse4_1 disabled.
sse4_2 auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -msse4.2 -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o sse4_2.o sse4_2.cpp
cc1plus: error: unrecognized command line option "-msse4.2"
make: *** [sse4_2.o] Error 1
sse4_2 disabled.
avx auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -mavx -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o avx.o avx.cpp
cc1plus: error: unrecognized command line option "-mavx"
make: *** [avx.o] Error 1
avx disabled.
neon auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -mfpu=neon -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o neon.o neon.cpp
Assembler messages:
Error: unknown floating point format `neon'
Error: unrecognized option -mfpu=neon
neon.cpp:1: error: invalid floating point option: -mfpu=neon
make: *** [neon.o] Error 1
neon disabled.
zlib auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o zlib.o zlib.cpp
zlib.cpp:42:18: error: zlib.h: No such file or directory
zlib.cpp: In function 'int main(int, char**)':
zlib.cpp:46: error: 'z_streamp' was not declared in this scope
zlib.cpp:46: error: expected `;' before 'stream'
zlib.cpp:47: error: 'stream' was not declared in this scope
zlib.cpp:48: error: 'zlibVersion' was not declared in this scope
zlib.cpp:51: error: 'compress2' was not declared in this scope
make: *** [zlib.o] Error 1
zlib disabled.
libjpeg auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o libjpeg.o libjpeg.cpp
libjpeg.cpp:45:21: error: jpeglib.h: No such file or directory
libjpeg.cpp: In function 'int main(int, char**)':
libjpeg.cpp:50: error: 'j_compress_ptr' was not declared in this scope
libjpeg.cpp:50: error: expected `;' before 'cinfo'
libjpeg.cpp:51: error: 'cinfo' was not declared in this scope
libjpeg.cpp:51: error: 'jpeg_create_compress' was not declared in this scope
make: *** [libjpeg.o] Error 1
libjpeg disabled.
libtiff auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o libtiff.o libtiff.cpp
libtiff.cpp:42:20: error: tiffio.h: No such file or directory
libtiff.cpp:50:6: error: #error "Required libtiff not found"
libtiff.cpp: In function 'int main(int, char**)':
libtiff.cpp:57: error: 'tdata_t' was not declared in this scope
libtiff.cpp:57: error: expected `;' before 'buffer'
libtiff.cpp:58: error: 'buffer' was not declared in this scope
libtiff.cpp:58: error: '_TIFFfree' was not declared in this scope
libtiff.cpp:62: error: 'TIFFReadRGBAImageOriented' was not declared in this scope
make: *** [libtiff.o] Error 1
libtiff disabled.
libmng auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o libmng.o libmng.cpp
libmng.cpp:42:20: error: libmng.h: No such file or directory
libmng.cpp:50:2: error: #error System libmng version is less than 1.0.9; using built-in version instead.
libmng.cpp: In function 'int main(int, char**)':
libmng.cpp:46: error: 'mng_handle' was not declared in this scope
libmng.cpp:46: error: expected `;' before 'hMNG'
libmng.cpp:47: error: 'hMNG' was not declared in this scope
libmng.cpp:47: error: 'mng_cleanup' was not declared in this scope
make: *** [libmng.o] Error 1
libmng disabled.
libpng auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o libpng.o libpng.cpp
libpng.cpp:42:17: error: png.h: No such file or directory
libpng.cpp:45:4: error: #error "Required libpng version 1.0.17 not found."
libpng.cpp: In function 'int main(int, char**)':
libpng.cpp:50: error: 'png_structp' was not declared in this scope
libpng.cpp:50: error: expected `;' before 'png_ptr'
libpng.cpp:51: error: 'png_ptr' was not declared in this scope
libpng.cpp:51: error: 'PNG_LIBPNG_VER_STRING' was not declared in this scope
libpng.cpp:51: error: 'png_create_read_struct' was not declared in this scope
make: *** [libpng.o] Error 1
libpng disabled.
DB2 auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o db2.o db2.cpp
db2.cpp:42:20: error: sqlcli.h: No such file or directory
db2.cpp:43:21: error: sqlcli1.h: No such file or directory
make: *** [db2.o] Error 1
DB2 disabled.
InterBase auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o ibase.o ibase.cpp
ibase.cpp:42:19: error: ibase.h: No such file or directory
make: *** [ibase.o] Error 1
InterBase disabled.
MySQL (thread-safe) auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o mysql.o ../mysql/mysql.cpp
../mysql/mysql.cpp:42:19: error: mysql.h: No such file or directory
make: *** [mysql.o] Error 1
MySQL (thread-safe) disabled.
MySQL (thread-unsafe) auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o mysql.o mysql.cpp
MySQL (thread-unsafe) disabled.
OCI auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o oci.o oci.cpp
oci.cpp:42:17: error: oci.h: No such file or directory
make: *** [oci.o] Error 1
OCI disabled.
ODBC auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o odbc.o odbc.cpp
odbc.cpp:45:17: error: sql.h: No such file or directory
odbc.cpp:46:20: error: sqlext.h: No such file or directory
make: *** [odbc.o] Error 1
ODBC disabled.
iODBC auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o iodbc.o iodbc.cpp
iodbc.cpp:42:17: error: sql.h: No such file or directory
iodbc.cpp:43:20: error: sqlext.h: No such file or directory
make: *** [iodbc.o] Error 1
iODBC disabled.
PostgreSQL auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o psql.o psql.cpp
psql.cpp:42:22: error: libpq-fe.h: No such file or directory
psql.cpp: In function 'int main(int, char**)':
psql.cpp:46: error: 'PQescapeBytea' was not declared in this scope
psql.cpp:47: error: 'PQunescapeBytea' was not declared in this scope
make: *** [psql.o] Error 1
PostgreSQL disabled.
SQLite2 auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o sqlite2.o sqlite2.cpp
sqlite2.cpp:42:20: error: sqlite.h: No such file or directory
make: *** [sqlite2.o] Error 1
SQLite2 disabled.
unknown SQL driver: sqlite_symbian
TDS auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o tds.o tds.cpp
tds.cpp:42:22: error: sybfront.h: No such file or directory
tds.cpp:43:19: error: sybdb.h: No such file or directory
make: *** [tds.o] Error 1
TDS disabled.
NIS auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o nis.o nis.cpp
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -Wl,-O1 -Wl,-rpath,/usr/local/Trolltech/Qt-4.7.3/lib -o nis nis.o     -lnsl
NIS enabled.
Cups auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o cups.o cups.cpp
cups.cpp:42:23: error: cups/cups.h: No such file or directory
cups.cpp: In function 'int main(int, char**)':
cups.cpp:46: error: 'cups_dest_t' was not declared in this scope
cups.cpp:46: error: 'd' was not declared in this scope
cups.cpp:47: error: 'cupsGetDests' was not declared in this scope
make: *** [cups.o] Error 1
Cups disabled.
D-Bus auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o dbus.o dbus.cpp
dbus.cpp:43:23: error: dbus/dbus.h: No such file or directory
dbus.cpp:46:2: error: #error Needs at least dbus version 1
dbus.cpp: In function 'int main(int, char**)':
dbus.cpp:51: error: 'dbus_shutdown' was not declared in this scope
make: *** [dbus.o] Error 1
D-Bus disabled.
Glib auto-detection... ()
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-g++ -c -pipe -O2 -Wall -W  -I../../../mkspecs/qws/linux-arm-imx -I. -o glib.o glib.cpp
glib.cpp:44:18: error: glib.h: No such file or directory
glib.cpp: In function 'int main(int, char**)':
glib.cpp:49: error: 'GSource' was not declared in this scope
glib.cpp:49: error: 'source' was not declared in this scope
glib.cpp:50: error: 'GPollFD' was not declared in this scope
glib.cpp:50: error: 'pollfd' was not declared in this scope
glib.cpp:51: error: 'g_thread_supported' was not declared in this scope
glib.cpp:52: error: 'NULL' was not declared in this scope
glib.cpp:52: error: 'g_thread_init' was not declared in this scope
glib.cpp:53: error: 'g_main_context_default' was not declared in this scope
glib.cpp:54: error: 'g_source_new' was not declared in this scope
glib.cpp:55: error: 'g_source_add_poll' was not declared in this scope
make: *** [glib.o] Error 1
Glib disabled.
Phonon support cannot be enabled due to functionality tests!
 Turn on verbose messaging (-v) to ./configure to see the final report.
 If you believe this message is in error you may use the continue
 switch (-continue) to ./configure to continue.
I have no idea where this error is coming from but I have followed every guide I can find to building Qt but constantly come up against this. I have Phonon installed and it is required for my board!
Any help would be great.
