Dear Pascal,
I used Processor Expert to generate linker, when I compile the simplest sample in IDE and it is OK. But I used commandline , it has error is
Warning : Linker command file warning at line 80
Object "F_EntryPoint" not found in file "Cpu.c"
Alert : Link failed.
Errors caused tool to abort.
I used the linker flag:
-l"FP5800.lib" -l"MSL C 56800.Lib" -timing -msgstyle IDE -stdlib -g -w on -maxerrrs 5 -maxwarnings 5 -m F_EntryPoint
