zetta shao
about Windows CE 6.0 at i.MX35
Discussion created by zetta shao on Nov 14, 2011
Latest reply on Nov 15, 2011 by zetta shao
Board is customer board, CPU is i.MX353, with MC13892.
Before this problem, Windows CE can suspend and resume regular, at one day, i build a trouble version OS for the board, and can't suspend. suspend process hang at function:
"extern "C" void HCD_PowerDown(DWORD hDeviceContext)"
return.
I clean the NAND flash, and re-burning old version (can suspend/resume) firmware, XLDR, e-boot, NK, but problem still exist, still can't into suspend, I'm only know some non-volatile memory like NAND-flash, eFUSEs at i.MX35 CPU, I clean all of NAND block and confirm eFUSEs does not change between suspend/resume workable board and this problem board.
and what i can insert debug message to any driver? I insert debug message at every  i can found driver that had "xxx_PowerDown" function, the lastest message at "void HCD_PowerDown(DWORD hDeviceContext)" function return.
any idea?
thanks everyone.
