I am facing the below problem in getting the kernel source code from
kernel.org with the tag of 2.6.35.3
ubuntu@ubuntu-laptop:~/IMX_
Yes, it was updated before kernel.org become offline.
Please use the procedure I posted on the other post you created:
As am following the below mentioned tutorial
In section
As u mentioned earlier, for getting the kernel source code from the below link:
Thanks for your replies, i was able to download the kernel from the below link
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git
I was able to download the kernel source code
But wen i executed the nxt command ie.,
git checkout v2.6.35.3
I got the below error
ubuntu@ubuntu-laptop:~/IMX_Android/kernel_imx$ git checkout v2.6.35.3
error: pathspec 'v2.6.35.3' did not match any file(s) known to git.
I neglected the error as am in *master branch so I proceeded nxt, but i finally got error in the below command
In section
wen I was applying i.MX Android patches by performing the executing the below command:
ubuntu@ubuntu-laptop:~/IMX_Android$ c_patch /home/ubuntu/IMX53/BSPs/imx-android-r9.4/imx-android-r9.4/code/r9.4/r9.4 imx_r9.4
Parsing basefile /home/ubuntu/IMX53/BSPs/imx-android-r9.4/imx-android-r9.4/code/r9.4/r9.4/baseversion...
Check work tree and patch dir based on /home/ubuntu/IMX53/BSPs/imx-android-r9.4/imx-android-r9.4/code/r9.4/r9.4/baseversion...
Checking CHANGE project - bootable/bootloader/uboot-imx ...
Checking CHANGE project - kernel_imx ...
fatal: bad object 6d23f5084c975be637f7d748db82116bf84d3872
Error! Base version commit 6d23f5084c975be637f7d748db82116bf84d3872 doesn't exist in git /home/ubuntu/IMX_Android/kernel_imx. Stop
Could you please do the needful in resolving the above issues as son as possible
Awaiting for your replies,
Advance Thanks,
Srinivasan
mail id: srinivasan.rns@gmail.com
Daiane Angolini said:
It's working for me:
git clone https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git
Initialized empty Git repository in /home/angolini/teste/linux/.git/
remote: Counting objects: 743584
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux.git;a=summary
