grantw
CodeSourcery (lite) C-function printf
Discussion created by grantw on Nov 10, 2011
Saved FAQ from Freescale.com for information only:
Topic: Compiler, Software Development
Question.  CodeSourcery (lite) C-function printf does not work properly when newlib is used with floating point numbers for bare board.
Answer.  C-function printf uses memory allocation (malloc) especially for floating point numbers. Therefore please double check function _sbrk in syscalls.c. The simplest implementation is provided below.
extern char _end; /* Defined by the linker */
caddr_t _sbrk(int incr)
static char *heap_end = &_end;
char *return_heap_end;
if (heap_end == 0) { heap_end = &_end; }
return_heap_end = heap_end;
if (heap_end + incr > stack_ptr())
{_write (1, "Heap and stack collision\n", 25); return((void *) -1); }
heap_end += incr;
return (caddr_t) return_heap_end;
Also please pay attention on alignment of sections in linker file. An example may be found below.
ENTRY(ResetHandler)
SECTIONS
. = 0x8200000;
.text :
{ *(.vectors);
. = ALIGN(4);
*(.init);
. = ALIGN(4);
*(.text);
. = ALIGN(4);
.data : { . = ALIGN(4); *(.data) }
.bss :
. = ALIGN(4);
_bss_start = .;
*(.bss)
_bss_end = .;
. = ALIGN(4);
_end = .;
. = 0x8200000 + 512K ;
.stack :
. = ALIGN(4);
STACK_ADR = . ;
Related Products:
 i.MX Applications Processors > i.MX51 Processors > i.MX512, i.MX513, i.MX514, i.MX515, i.MX516
