If i try to use aplay or gplay , it says "-sh: aplay: not found". What might be the reason for it.?
You should enable alsa packages on LTIB packages.
Are you using ltib to generate rootfs?
Hi Daiane Angolini, Thanks for your reply. I generated rootfs using ltib and i created spdif as a module. I uploaded config file which was used for building rootfs. What are the packages required for aplay.
