Jesus Ortiz
Read/Write on EEPROM
Discussion created by Jesus Ortiz on Mar 16, 2007
Latest reply on Mar 19, 2007 by Jesus Ortiz
I'm working with MC9S08DZ60 and I have a problem that I can't solve because I don't find the information in the data sheet (MC9S08DZ60.pdf). On page 52, paragraph 4.5.3. "Program and erase comand execution", the first step says "Write a data value to an address in the FLASH or EEPROM array". How can I do this with CodeWarrior and C code (not assembly)?
For example, if I want to write the data 0x33 in the EEPROM address 0x1650, I have tried the following:
0x1650 = 0x33;
But when I compile, the application goes into error.
Other question for you is: how can I read directly from an EEPROM address?
I know this issues are quite simple, but I'm starting to program microcontrollers and those kind of troubles are the worst for me, because they don't appear in the datasheet and I can't solve them by reading the documentation.
