Shyam Rachamalla
Regd:BeeStack
Discussion created by Shyam Rachamalla on Mar 13, 2007
Latest reply on May 21, 2008 by Janell Armstrong
I have downloaded the new evaluation BeeStack from freescale. I tried to work on WirelessUART example by creating two projects: coordinator and router. I have downloaded those projects onto two NCB boards. I could form a network and was able to shift between two modes: Config mode and application mode. When I tried to pass data in char mode using hyperterminals between boards - I was never successful.
When I try to pass data from router to coordinator I could see the LED3 blinking which indicates the board is putting out the data over the air. But I never saw any data being received by coordinator
Did any one had a chance to work on new Beestack and on wireless UART example?
If any one was able to transmit data in full-duplex mode I would be grateful for your suggestions.
Thank you
