Hi ramabh,
On the very limited information you have given I can suggest two possible issues:
1. FCDIV is "write once". That is only the first write to this register after a reset will be honoured.
2. FCMD is "write only" attempts to read it will always give 0.
Give us some more info on your problem and we may be able to help you more.
