Connector or Cable for USBSPYDER08
Dakota
Good Morning,
I searched this forum for the answer to my question, but could not find a relevant post.
Does anyone know where to purchase either a polarized, 6 contact IDC connector that will mate to the USBSPYDER08, or a ribbon cable connector with 6 contacts?  The smallest connector that I can find has 10 contacts, and it will not fit in the socket.
I think that I could probably modify a 10 contact connector, or connect to the vertical 6 pin header, but there should be a cleaner way to use the BDM port.
Thank you.
baddad
The 6-pin IDC connectors are hard to find.
Witztronics sells a 12", 6-pin IDC cable on their web site:
Maybe that will help.
BadDad
Dakota
Good Morning,
Thank you for the information.  This will definitely get me started without having to cut and modify existing connectors.
In Fall 2007, I am teaching a control systems class, and it would be nice to have some 6 contact ribbon connectors (not the pre-built cable assemblies), but the cable assemblies will work if no connectors can be found by that time.
