NE64 No Full Duplex
NE64 No Full Duplex
Jordan
I am trying to get a slightly modified version of the Connector Application code to come up in full duplex (no auto-negotiation), but it seems to refuse. The EMAC and EPHY registers report full duplex but my network switches (linksys, lantech, cisco) disagree.
Jordan
Aleks
I was just wondering did you find a solution to this problem? I have run into the same issue where the NE64 is being set in Full duplex mode but the GarretCom switch is saying half duplex.
Many Thanks
Jordan
No solution was ever found. I have moved on and no longer use the NE64
