jose afonso
I/O problem with 9s12DP512
Discussion created by jose afonso on Mar 8, 2007
Latest reply on Mar 8, 2007 by jose afonso
Hy,
I use an 9s12DP512 to replace the 256 in a new board...
I have an strange problem with the port K, specially with the PK4 pin:
all the others pin could work in input or output...but when i try to use the PK4 oin in output it don't work...i coud just use it in input....is that normal??? or did i forget something, i haven't found sommething about it in the datasheets...
If somebody know's...
Thanks for your help....
Regards.
Wish.
