A bit more details about "my stuff": GCC from CodeSourcery and usage of M52235EVB. From ethereal sniffing, the 52235 sends an ARP request for the configured gateway address, and receives a valid reply to this.
I guess this is parts of the answer (correct me, if this is incorrect):
- use power-up code similar to the niche web-server (without the tasks and web-server)
- call inet_timer() from timer_isr()
- call packet_check() from timer_isr() (??)
These attempts on simple low-level data transfer has failed:
- send data with udp_send() (no relevant data found in ethereal)
- receive data by using udp_open() and waiting for callback function (no callback)
- listen on TCP port with m_listen() and wait for connect (no callback when attempting to connect to 52235 with netcat)
Does anyone have a tip or success story to share with us?
Here is a dump of (strategic) parts of my "ipport.h" file:
#define SUPERLOOP 1
#define INCLUDE_ARP 1 /* use Ethernet ARP */
#define FULL_ICMP 1 /* use all ICMP || ping only */
#define OMIT_IPV4 1 /* not IPV4, use with MINI_IP */
#define MINI_IP 1 /* Use Nichelite mini-IP layer */
#define MINI_TCP 1 /* Use Nichelite mini-TCP layer */
#define MINI_PING 1 /* Build Light Weight Ping App for Niche Lite */
#define BSDISH_RECV 1 /* Include a BSD recv()-like routine with mini_tcp */
#define BSDISH_SEND 1 /* Include a BSD send()-like routine with mini_tcp */
#define NB_CONNECT 1 /* support Non-Blocking connects (TCP, PPP, et al) */
#define MUTE_WARNS 1 /* gen extra code to suppress compiler warnings */
//#define IN_MENUS 1 /* support for InterNiche menu system */
#define NET_STATS 1 /* include statistics printfs */
#define QUEUE_CHECKING 1 /* include code to check critical queues */
//#define INICHE_TASKS 1 /* InterNiche multitasking system */
#define MEM_BLOCKS 1 /* list memory heap stats */
// EMG #define TFTP_CLIENT 1 /* include TFTP client code */
// EMG #define TFTP_SERVER 1 /* include TFTP server code */
// EMG #define DNS_CLIENT 1 /* include DNS client code */
#define INICHE_TIMERS 1 /* Provide Interval timers */
// EMG #define DHCP_CLIENT 1 /* include DHCP client code */
// EMG #define INCLUDE_NVPARMS 1 /* non-volatile (NV) parameters logic */
#define NPDEBUG 1 /* turn on debugging dprintf()s */
// EMG #define VFS_FILES 1 /* include Virtual File System */
// EMG #define USE_MEMDEV 1 /* Psuedo VFS files mem and null */
#define NATIVE_PRINTF 1 /* use target build environment's printf function */
#define NATIVE_SPRINTF 1 /* use target build environment's printf function */
#define PRINTF_STDARG 1 /* build ...printf() using stdarg.h */
#define TK_STDIN_DEVICE 1 /* Include stdin (uart) console code */
#define BLOCKING_APPS 1 /* applications block rather than poll */
#define INCLUDE_TCP 1 /* this link will include NetPort TCP w/MIB */
#define tk_yield packet_check
#define SignalPktDemux() ;
