ETPU Pad Configuration
Fabrice
I'm using a MPC5554 and more specifically the ePTU onboard. But I have some problems with the PAD configuration. In the documentation, I find that eTPU pads had to be set through SIU_PCR registers. Fore eTPU, these registers are from 113 to 178.
I set PCR register for channels on eTPU A to 0x0C00 in order to set pads to their primary function (eTPU A).
After configuring PCR registers, I download microcode into eTPU. I configure active channels. But, no signal appears on these pads.
Hava you any more information about this issue.
Thank you for your help.
Fabrice
Fabrice
I solve my problem. It is a problem with the PCR registers and more specifically with the Board I used for my tests.
Another problem occurs. How can i configure my input channel in order to detect a continuous signal ?
Thanks for answers.
