Tong Yin
Help w/ Bus Error with MCF5213EVB Please!
Discussion created by Tong Yin on Feb 22, 2007
Latest reply on Mar 1, 2007 by Paul McConkey
Hi, I've been programming a lcd, upto this point it all worked until i made modifications to the line 1038 in main.c, the case 1 of the switch statement is same as case 0; case 0 works perfectly, but when i take out the commenting on the case 1, it does not work for some reason and gives me a bus error. Has anyone gotten this problem? Thanks a lot!
Tong Yin
attached is the project file
Message Edited by t.dowe on 2009-10-21 02:24 AM
