Hello
If you have a CodeWarrior V3.1, you have two solutions:
1- You upgrade to V5.1 Special edition license is available for free when you install that software.
2- If you need to stick with V3.1, I have attached a V3.1 special edition license for your convenience.
Just rename the attached file to license.dat and place it in your V3.1 root installation directory.
Do not use that file for V5.x. These versions are installing a special Edition license automatically.
I hope that helps.
CrasyCat
