Pavel Velikov
Timer in QL4
Discussion created by Pavel Velikov on Feb 18, 2007
Latest reply on Aug 20, 2007 by Pavel Velikov
I need to make an application which has a free running counter or a PWM to generate a signal with square form and duty cycle 50%. This signal will have variable ratio, changed dynamically in the code. Except this I need also an interrupt each 10ms for handling some other events.
How can I combine these two counters in QL4?
