MARK BEWLEY
QSB not working with U-boot instructions. -blog archive
Discussion created by MARK BEWLEY on Jul 25, 2011
Latest reply on Aug 16, 2011 by Vladan Jovanovic
If  follow the instructions from Quick Start Guide for i.MX54 QSB. It appears  that maybe the sync freq is not working. There is a column about 1/5 of the lcd width that has the lcd screen layered in it. I did test the lcd when I first received the kit and the lcd work fine out of the box. I am running same sd card that came with kit. Only change has been toset bootregs to setup lcd.
Any ideas.
Mar
