Programming Certification
gabryray
Hi, I'm developing a software for MC9S12XDT512 Flash-EEprom  programming  and I need to obtain a FreeScale quality certificate but I don't know which is the procedure. Samebody can help me?
Thanks in advance....
ps: I'm sorry for my bad english, I'm Italian.
Alban
Senior Contributor II
What kind of Quality Certificate do you need ?
Cheers,
Alban.
gabryray
Hi, I need to Obtain an Assessment that certificate the quality of my programmer because  my customer request a certificate of quality. Thanks
Alban
Ok, I see,
Which programmer are you using ?
Which kind of certificate ? I ask because Quality is at every level.
Alban.
gabryray
I work for SPEA (www.spea.net) and I use an ON BORD PROGRAMMER  developed by SPEA and I need a certificate that attest that the component is fine programmed with OUR hardware and software.
thanks
Alban
Hello and thanks for the details.
This kind of Certificate would have to be obtained from the manufacturer.
Only them know how they implemented Flash programming in their product.
I found a contact at SPEA. They own the Intellectual Property of the module and FSL is not supposed to know what they did.
Good Luck,
Alban.
