Hi all,
I'm trying to boot up the OS from a SATA HD. Before that, I need to figure out which version of imx53 I am using.
the label indicates it is REV. E, but I believe the hardware reference manual never indicated what Rev E stands for.
Many thanks!
-Ray
Actually, I just found this information:
http://www.scribd.com/doc/49842657/i-MX53-Multimedia-Applications-P...
on the Part Numbering slide it describes the part numbering of the i.MX53 chip. The final character represents the revision number (distinct from the HW manual, it appears). B=2.0, C=2.1
HTH.
EDIT: I should say that this is the number printed on the CPU itself, not the label.
Hi Matt,
Nope, I can't find any information either.
Hi.
If you've found where to find this information, could you please post it? I'm looking for the revision number also.
