hr hr
gstreamer definitely broken iMX5X
Discussion created by hr hr on Jun 26, 2011
Latest reply on Aug 15, 2011 by William Smith
There is a problem with the gstreamer alsa library.
Excuting the following basic command does not work:
"gst-launch  alsasrc ! alsasink"
The above statement works on just about every linux system (pc or embedded).
I've tried different BSP from the Freescale site but I get the same issue.
Fyi, I can play and record audio separately using aplay/arecord.  I suspect there is something with the alsasink module.
Any ideas anyone?
