robert zdunski
how to use inflexion UI express (exported) output files
Discussion created by robert zdunski on Jun 26, 2011
Latest reply on Jun 30, 2011 by robert zdunski
on http://www.mentor.com/embedded-software/inflexion/ui-imx-processors?mgctab=0,4#tabs it says:"UIs can be quickly tested in the preview window before deploying to the target device. The transition from the UI Express to device software requires only few mouse clicks."
Anybody knows what is meant by those "few mouse clicks"?
I can write an application and deploy it to the target device through Eclipse, but what to do with the (exported) output of Inflexion UI Express so that it can be integrated with existing code in Eclipse?
Should I use different approach perhaps?
