M5213EVB problem with illegal instructions
Sprtng
Hi, I have the MCF5213EVB, and when I tried to compile the program i wrote for the board, it reports an error in one of the MCF5213xxx.h files, and it says that the instruction movec is not supported by the targetting processor. There are 3 similar errors, does anybody know which did this happen? Thank you!
Nouchi
Senior Contributor II
Can you post your project directory, it will be easier to diagnose.
regards,
Emmanuel
Sprtng
Thank you Emmanuel, I'm downloading the update right now, I'll see if that takes out the illegal instructions for targetting microprocessor error and I'll get back to you.
Tong
Sprtng
Here's the project directory, thanks so much for replying!
Tong
Message Edited by t.dowe on 2009-10-21 02:29 AM
Nouchi
First, you might upgrade your CodeWarrior to 6.3, here :
https://www.freescale.com/webapp/Download?colCode=COLDFIRE-07-24-2006&nodeId=0127260061788214091513&...
Sorry, but your project contains too many errors, (more than 100), is this the right project?
Emmanuel
Message Edited by BugMan on 2007-02-0808:38 AM
Sprtng
Sorry, that was indeed a wrong project folder..I named them the same..sorry about that, I'll upload the correct folder shortly!
Tong
Sprtng
Here's the updated version.
Tong
Message Edited by t.dowe on 2009-10-21 02:25 AM
Nouchi
There was something weird in the init part, so I create a new project with your files and it seems to compile and works for the Internal ROM target (you have to use Flash tools indeed).
Emmanuel
GPS_Firmware.zip
Message Edited by t.dowe on 2009-10-21 02:26 AM
Sprtng
Hey Emmanuel,
  Yeah, there was something that's strange, I was working on it last night and was finally able to get it compile and run on the board after 10 hours of trying, haha.It come out to be that I had to rebuild the processor/whatever in order to get it to compile.. The joy, heh, Thanks so much for all your help!
Tong
