Ralf Flechsig
M5213EVB connection problem over QSPI
Discussion created by Ralf Flechsig on Feb 2, 2007
Latest reply on Feb 2, 2007 by stzari
Hello
I've got the M5213EVB and I try to connect it over QSPI with an EEPROM.
I checked all pins of the EEPROM with an oscilloscope, and everything is how I imagined.
But the SlaveOutput.
So can someone take a look at my code (only the QSPI code with an simple routine to write and read data over QSPI).
The important parameters of the EEPROM are listed at the top of the .c-file
thanks in advance for help,
