Lisa Johnson
MC9S12C32 - Debugging interrupts and some other questions
Discussion created by Lisa Johnson on Feb 1, 2007
Latest reply on Feb 2, 2007 by CrasyCat
Hi, I have several questions:
1. is there anyway with the codewarrior or some other tool to watch how the interrupts work? Or at least run the program for a while on the board and then stop and get the data from it?
2. When using a timer interrupt I define a function using it to be an interrupt 16.
What does this "16" mean and where can I find it in the vector table?
3. Any tutorial on writing/reading data from the board while it's running??
Thank you
