Hi Paul,
There are not embedded Flash programming routines in ROM on the bigger HC08 Flash devices because you have the space to put them in Flash.
It's also safer not to have these routines if your application is not writting memory as code run-away will not be able to corrupt it.
Cheers,
Alban.
