--------------------------------------------------------------------------------------//#include#include // for EnableInterrupts macro#define PRESCALAR 0 //7 // gives base pwm frequency#define MODULUS 32768 // pwm frequency = base pwm frequency / modulus#define DUTY50 16389#define MAX_DUTY MODULUS#define tLED1 PTCD_PTCD5#define tSW1 PTBD_PTBD6#define tSW2 PTBD_PTBD7unsigned int tpm2c0int = DUTY50;--------------------------------------------------------------------------------------//void main(void){unsigned char tpm2c0vh, tpm2c0vl;unsigned char changed_flag = 0;unsigned char temp_pot_value = 0;PTADD = 0; //initialize as input (Data Direction Rregister// Configures PTB3 and PTC5 as output (USER LED1 & LED2)PTBDD = 0x08;PTCDD = 0x20;tLED1 = 1;//Initialize timer TPM2 channel, assumes not touched since reset!TPM2SC_CLKSA = 1;//Select BUS clockTPM2SC_CLKSB = 0;TPM2SC_PS = PRESCALAR;//clock source divided by prescalar/TPM2MOD = MODULUS;//set Counter modulusTPM2SC_CPWMS = 1; //set center aligned//configure PWM mode and pulseTPM2C0SC_MS0B = 1; //don't care for center aligned //MS0B=1, MS0A=0; Edge align PWM//TPM2C0SC_MS0A = 1; //don't care for center aligned or edge alignedTPM2C0SC_ELS0B = 1; // 1 = Select high as true, 0 = Select low as trueTPM2C0SC_ELS0A = 0; // 0 = Select high as true, 1 = Select low as trueTPM2C0V = tpm2c0int;TPM2C0SC_CH0IE = 1;TPM2C0SC = TPM2C0SC;EnableInterrupts;for(;;){__RESET_WATCHDOG(); //kicks the dogif(!tSW1){if(tpm2c0int MAX_DUTY-1){tpm2c0int++;changed_flag = 1;}}if(!tSW2){if(tpm2c0int > 0){tpm2c0int --;changed_flag = 1;}}if(changed_flag == 1){TPM2C0V = tpm2c0int;changed_flag = 0;}}// loop forever}//-----------------------------------------------------------------------interrupt 12 void T2CH0_cpwm (void){unsigned char dummy;dummy = TPM2C0SC_CH0F;TPM2C0SC_CH0F = 0;tLED1=~tLED1;dummy = TPM2SC;TPM2SC &= 0x7F;}//-----------------------------------------------------------------------
Message Edited by Alban on 2007-01-29 02:20 PM
