I use CodeWarrior IDE 5.7.0, HCS12X and C++.
My own SCI-Driver Class has only static Data Members and static Functions.
Code:
class CSCIDriver{public: static void RxInterrupt (); static unsigned char Data_read (unsigned char *Data);protected: static unsigned char Buffer[256]; static unsigned char Bufferpos;}
How can I debug static Data Members of a class? I can not see the static members in the global selection of the module CSCIDriver.cpp.
Message Edited by CrasyCat on 2007-04-13 11:10 AM
Solved! Go to Solution.
