Here is a testbench file, one can embed it into Fmd to do a test:
PVOID FMD_Init(LPCTSTR lpActiveReg, PPCI_REG_INFO pRegIn, PPCI_REG_INFO pRegOut)
DWORD i;
PVOID pResult;
UNREFERENCED_PARAMETER(lpActiveReg);
UNREFERENCED_PARAMETER(pRegIn);
UNREFERENCED_PARAMETER(pRegOut);
// 0. Setup global variables. Also may add more software logic here in future
memset(&g_FlashInfoExt, 0, sizeof(g_FlashInfoExt));
BSPNAND_GetFlashInfo(&g_FlashInfoExt);
// 1. initial NFC hardware
pResult = CSPNAND_Init(&g_FlashInfoExt);
if(pResult == NULL)
goto cleanUp;
// 2. initial nand chip and verify nand id
for(i = 0; i < g_FlashInfoExt.NumberOfChip; i++)
CSPNAND_Reset(i);
if(CSPNAND_ReadID(i) != g_FlashInfoExt.NANDIDCode)
pResult = NULL;
goto cleanUp;
if(g_FlashInfoExt.ILSupport && CSPNAND_ILSupport())
//silicon supports interleave mode & bsp needs interleave mode
g_bInterLeaveMode = TRUE;
NANDOperationTest();
if(!BBT_Init())
RETAILMSG(TRUE, (TEXT("InitializeBBT Fail\r\n")));
cleanUp:
return pResult;
