Hi susy,
Sometimes it says it is secure because it can't talk for some other reason (broken?)
But if it really is just secured, then use load on the PEDebug menu select your code and burn it in.
It will do a mass erase first which will get rid of the security.
Perhaps it is secured as additional protection for a bootloader programmed into it???
Hope this helps
Peg
