Nicholas Cooke
MCF52223EVB and USB Implementation
Discussion created by Nicholas Cooke on Jan 2, 2007
Latest reply on Jan 9, 2007 by James Williams
I have finally managed to get some semblance of operation out of the dev board .Can anyone point me in the direction of some software for implementing the USB port on the dev board. I have read all the documentation and tried to configure the USB port but I think I am tripping up on the configuration of the ports as I do not know exactly which pins must be configured in the PAR registers.
I have also tried to use the HID example code but cannot get that running. Is this the right stuff to get going with. I am only needing to hook a memory stick onto the USB port to get data on and off of.
Any ideas.
Many thanks.
