Raghav Sarma
Reprogramming/ Erasing flash while running code from it on HCS12!
Discussion created by Raghav Sarma on Dec 19, 2006
Latest reply on Dec 19, 2006 by Daniel Lundin
Hallo everyone,
Is it possible to write to / erase Flash memory while running code from Flash at the same time? Do you have to make sure that the Flash memory being erased /reprogrammed ids on a different block / page?
Cheers,
Raghav
