Interesting info: switch off and on again...
It sounds like a vulgar IT Technical Support Helpline where you support them
I thought that Lead Free was requiring a different soldering temperature, because of the absence of lead.
Are my thoughts wrong ?
Have you tried parts from a different batch (code below MCU part number) ?
May be something is wrong with your batch, but I doubt it as the device is used quite widely and I have to say I would have heard from it...
So let's investigate the Application:
It seems the failure can easily be repeated, that is great.
When you lose the MCU, it would be interesting to follow the RESET, VDDs, and CLOCK lines.
May be when the board is getting cold, the power supply characteristics affect the MCU.
Do you have schematics (or part of it) you could disclose ?
Same for the PCB layout ?
So we can check the MCU environment.
If you've got any objection or other element, feel free to express !
Same for other Community Members, feel welcome to share your experience !!!
Cheers,
Alban,
