Hi Terry,
I'm not sure you'll keep smiling, but I'll try anyway.
Is it data store/read you do from these locations, or code execution ?
Code Execution has a prefetch pipeline as documented in the CPU reference manual. If you fetch outside implemented memory, you get a Illegal Address Reset....
Cheers,
Alban.
