LUCIO SIMONI
External Bus ECLK Problem
Discussion created by LUCIO SIMONI on Nov 16, 2006
Latest reply on Nov 16, 2006 by LUCIO SIMONI
Im working with a 9S12A256 Micro in expanded wide mode.  I've followed the example in AN2408, using an HC374 to decode the Address/Data Bus.  I'm trying to write to external memory at address $0400 and $0402.  From what I can see on the scope, the Timing of the write instruction (STD $0400) does not follow the spec for address hold time (2ns).
Anyone else have this problem?  I've messed with clock stretching, but that doesn't do any good since the address is latched into the 374 on the rising edge of eclock.
