Hello
Which CPU are you targeting (HC08, HC12, Coldfire, ...)?
Which version of CodeWarrior are you using ?
To retrieve that info:
- Start IDE
- Select Help -> "About Freescale CodeWarrior"
- Press on "Installed Products"
- You will see CodeWarrior version info into the title bar.
Which cable are you using to connect to your target board( Multilink, USBTAP, ...)?
CrasyCat
