Jim Mood
56F800 USB TAP error message?
Discussion created by Jim Mood on Nov 14, 2006
Latest reply on Dec 20, 2006 by Giacomo Petrini
When trying to program a 56F8322 with the USB tap, I get the following error:
Error: Could not write to PRAM, this usually means the wrong configuration file was used
Well, the correct configuration file is being used, what else could be the cause of this error?
This occurs immediately after the "Placing device into debug mode" message, on both the command line "FFLASH.EXE" and with the windows GUI version.
Thanks in advance
-Jim
