I need to calculate 32*16 bit integer multiplication whete result may get longer than 32 bits. Is it possible to do 64 bit math in 56800E C compiler? In gcc type 'long long' equals 64 bit integer but is there equivalent in CW?
I also would be happy if result would saturate to 32 bits. How does saturation logic work in C? I haven't seen much documentation about it.
I'm using 56F8322 and CW 8.0.
