Brian Witzen
help with HC05 asm conversion to HCS08 asm
Discussion created by Brian Witzen on Nov 10, 2006
Latest reply on Nov 15, 2006 by Brian Witzen
Folks,
I am converting some old HC05 asm code to run on a HCS08AW32 (using CW 5.1).  I've been successful with everything but this subroutine:
XMT_EMSG0:
 ADD #MSG_LNK&0FF  ; Add LSB of Message Link Offset
 STA VSRL_LSB  ; Message in the EEPROM Pointer
 LDA VSWI
 ADC #MSG_LNK/100  ; Add MSB of Message Link Offset
 STA VSRL_MSB  ; Message in the EEPROM
This code is creating a 16-bit offset pointer to some messages.
The 2 add statements (ADD and ADC) create errors due to the complex statement.
Any suggestions on how to reduce these two lines to simple HC08 instructions that will assemble?
Thanks in advance.
Brian
