signal when debugger crashes
mel
The debugger seems to crash randomly.
If it crashes while I have a motor in boost it burns out the board.
Is there a signal from the processor that will let me know when the debugger
crashes? I am using codewarrior 7.3 on the 56f8357.
Oppie
Let me expand on this.
There are some high power processes under control of the processor. When emulation stops, we need a graceful way to shut down the power processes so that the board does not burn up.
Is there some hardware method to flag when emulation stops on a breakpoint or emulation failure?
codewarrior 7.3 on the 56f8357.   Emulating through the parallel port using OCDemon 'wiggler' jtag converter.
TIA
