I need to debug both the application and the library. I'm aware that I can load the library's symbols, either using:
LOADSYMBOLS "library.abs"
Or via:
LOAD "library.abs" SYMBOLSONLY
However, when I do this, the symbols for the app are discarded. Likewise, when I reload the symbols for the app, the library symbols are discarded. I *could* ping-pong back and forth, but that would s*ck. Is there a way I can keep both sets of symbols around at the same time?
Schwab
Phooey. Oh well...
CrasyCat wrote:HelloI assume you are using CodeWarrior for debugging. Am I right?This is not supported by CodeWarrior tools today.
Thanks for the info.
